4x4 dash lite constantly blinking
fordguy1948
The 4x4 dash lite on my 1999 Exp blinks continuously. The vehicle was sitting in my driveway for 4 days while I was on vaction. Came home, started it up, began to drive and........there is was, blinking. I had the fluid changed in the transfer case thinking maybe that would help; to no avail. Can anyone tell me what this lite means? If it is attached to a sensor or sending unit, where is it located?
AvroAero
Toronto, Ontario
Maybe the motor went on the transfer case, do you see it moving/making noise?
Does it switch over to 4wd then back to 2? I mean actually, you'll have to test it on grass or wet pavement.
F
fordguy1948
Yes, I have tested it several times. It always switches over to 4 wd high and into 4 wd low then back to 2 wd.... all seems to operate ok. When it is in 4wd, if I turn the wheels to make a rather sharp turn, there is a loud "thunk" sound....maybe 2 or 3 "thunks" if I continue the turn. I know that it is common on high mileage vehicles for there to be a "wobble" in the steering. This "thunk" seems to maybe be a little more. What do you think? Is it possible that the motor may be loose? I appreciate your input.
AvroAero
Toronto, Ontario
I have a 99 Expy and the thunk isn't normal. Although if your on a high traction surface you'll hear it struggling because its under pressure from the turn (in 4wd). A guy that worked with me had a jeep cherokee all time 4wd and he had the same problem of the thunk noise on turns. The mechanic changed the axles, rebuilt the driveshaft a few times, and then the axles again (think the dealer messed up the order on the first axle) and it went away. But it came back after a while.
Mind you the mechanic isn't the best. Do you have a computer reader? Check the code. I'd have a mechanic check the front end. The diff, or the axles are problemed I'd guess. The steering on mine is a little different than normal vehicles but I think its the speed sensative steering that gives it that feel.
Btw, your going into netural first before going into 4 low right? Otherwise its still in high. Prob not the problem, but you'll be able to know for sure its going into low.
F
fordguy1948
Hey, thanks for responding. My brother-in-law, who is a mechanic but lives 6 hrs away, suggested that it may be a CV joint. I'm planning to take the Expy to a local mechanic next week to have it put on the rack and do a little investigating.
I know to put the shift lever into N when shifting into 4 low. That seems to work just fine.
I still would like to know why the 4x4 light blinks at the dash and, if it is attached to a sensor, where is the sensor located? I don't have a code reader but I have been told that this light will not produce a code.
99EB4x4
St Louis
isnt there 2 seperate motors on the transfer case? in Auto 4wheel it can apply a little power to the front or 50-50 front rear. but when in 4high and 4low its locked in 50-50 mode thats why it binds on high traction surfaces. so wouldnt there be a motor that operates the clucth and a seperate motor to switch from auto4x4 4high and 4low?
Copper93
Charlotte, NC
The auto 4wheel works off an electro magnet and clutches. When in auto, it pre loads the clutches for a quicker response. I don't think there is a motor. When you started the truck after sitting did it crank right up or did it lug like the battery was weak? Cranking on a weak battery can cause similar problems. You can try pulling the battery for a minute and resetting the system.
