studabaker
I have had an excessive noise from my suspension for while now and a shop told me my ball joints were bad and I thought this was something I could do. I got one side done with several challenges that took me late into the night to complete. After seeing the identical vehicle done online i decided to tackle it. I got the press but there is a step prior which requires a special removal fork which i had to take time to get. i ended up using some other puller tools on the removal of the joint from the knuckle. I then attached the c-clamp press however I had the wrong attachment and had pressed the ball joint onto itself as pictured. This cancels and forces driving the bad ball joints through, with some hammering the ball joint went through.
