Heated and cooled seats are weak and passenger side seat does not work
pkuchirka
CA
The heated and cool seats don't heat up much or cool . I checked the filter under the seats, checked the fuses and there good. Now the passenger side doesn't work at all now. Any advice on what else I can look at to get this fixed? Thank you
Sent from my HTC One M9 using Tapatalk
ExpeditionAndy
Fort Wayne, Indiana
I had an 05 that I bought used the heated and cooled seats barely worked, the heat worked better but it took a little while for the heat to come up and it the the cooling about 10 minutes before you felt it, compared to the new 17 that gives me heat in about 30 seconds and cooling in about the same amount of time. The seats work with fans under the seats and they have filters. First check the filter, they probably aren't dirty but it is worth the time to check them.
My guess is the foam collapses over time and it makes it hard for the air to come through the holes in the leather. That is just my thoughts, I haven't confirmed it but it seems logical.
P
pkuchirka
CA
I have checked the fan filters for the seat and they were good. Do you think the fan is weak? The seat foam sounds like something to check out!
ExpeditionAndy
Fort Wayne, Indiana
The fans are probably good I don't think they get used as much as other systems. The foam would be what I would suspect. Over time it deteriorates.
I know there is a plastic duct that goes up the back of the seat back but there has to be channels in the foam that allow the air to come up through the perforations.
That's my guess.
P
pkuchirka
CA
Thank you. The foam makes sense! I'll have to get them redone
slyrose
Chicago
9131 is a picture of the working passenger seat, the other is the driver's seat with the non-functioning bottom. Ordered a used one and it doesn't heat or cool either.
ExpeditionAndy
Fort Wayne, Indiana
Welcome to the forum. Did the seat that you bought specially have heating and cooling in it or was it a non heat and cooled seat?
slyrose
Chicago
I bought the TED to replace a non-functioning unit in the heated/cooled seat that came in the auto.
P
pkuchirka
CA
I wonder if there is a separate module or relay under the seat... there no fuses blown. Pass seat does not work at all
ExpeditionAndy
Fort Wayne, Indiana
There was a TSB about the control module for the heating and cooled seats in the 2nd gens that said something about a terminal that overheated and burn out. You might try searching for the climate controlled seat module or something like that to see if you can find it. I also think there was a couple of videos on YouTube.
P
pkuchirka
CA
Thank you very much I will do some searching !
