Overheating message
dlcorbett
Air Force
tx
Has anyone seen an "overheating coolant" message for their 2015+ expys? What did your dealer or mechanic say about this?Got the message though the temp gauge showed Cold, and now the truck is undrivable.
Does the truck turn over and start? When did this occur? What confuses me is you said it’s not driveable. I’m not sure on the 3.5 EcoBoost but on the 5.4 Triton there is a fail safe cooling mode in the event of a failure. The ECM alternates cylinders and shuts off combustion to pump air through the engine to cool. You get a warning but the engine won’t shut down for safety reasons.
I guess it’s possible that’s not smart on the ecoboost with the extra heat of the turbos...was the engine cool and recently started? Maybe a sensor mishap? You sure have had no breaks with this truck, she has been a shop queen. Hope all gets sorted out.
Since I’m not an ecoboost owner nor have I had an overheat I’m no help. Hopefully others chime in and my reply acts as a “bump” for you.
1955moose
As usual, the $64.00 question is are you doing the work? Or a shop? If your doing the work, obviously you start at the basics. Does it have sufficient coolant, is the thermostat opening at desired temp, is fan switch kicking fan on. Beyond that, it gets fun. Is the radiator flowing, is the pump pumping? Etc, etc.
dlcorbett
dlcorbett
Air Force
tx
Honestly, its not mine. A friends truck juat started doing this by her knowledge today and almost left her stranded.
1955moose
Well we can turn this into a 25 plus post hypothesis, or she can bring it to the dealer/shop, and report back what it took to fix. We live to help here, but if she's having it repaired, rather than doing it herself, it would save a ton of time, and effort on all concerned. Thanks for being honest on whose vehicle it is.
Pilgrim
SK. Canada
What was the end of this? I had the same issue but hooked up a scanner and watched temps. All over and very erratic. Goes from 195 down to 25 degrees in about 1 second. Never shows overheating, but does trigger the "coolant overheating" message on the message center. It does not seem like it's overheating under the hood. It acts like a faulty sender, except it never goes over 195 and I can't explain the overheating message on the message center.
07navi
Mt.Shasta California
Like it said above it should go into limp where it fires on 4 cylinders, alternates firing pattern, induces cool air, drops your max speed down to about 50, and eventually will shut down but will restart and go through the same pattern to get you to a safe place. Maybe the Ecoboost doesn't have that feature IDK. Just being low on water will induce limp mode. A big mistake people make is putting an aftermarket thermostat in these modulars which doesn't shut off and regulate the bottom passage correctly. It's definitely best to spend a couple more dollars and get the proper Motorcraft thermostat. It's not like 30 years ago when thermostats just open and close at the right time. Also being very low on water can lose water/coolant contact with the sender giving erratic and inaccurate readings.
ManUpOrShutUp
Like it said above it should go into limp where it fires on 4 cylinders, alternates firing pattern, induces cool air, and eventually will shut down but will restart and go through the same pattern to get you to a safe place. Maybe the Ecoboost doesn't have that feature IDK. Just being low on water will induce limp mode. A big mistake people make is putting an aftermarket thermostat in these modulars which doesn't shut off and regulate the bottom passage correctly. It's definitely best to spend a couple more dollars and get the proper Motorcraft thermostat. It's not like 30 years ago when thermostats just open and close at the right time. Also being very low on water can lose water/coolant contact with the sender giving erratic and inaccurate readings.
My OEM tstat crapped out 4 years in. Originally, I picked up a Motorcraft replacement from the dealership, but it weighed about 1/2 of the OEM one and just seemed like it was poorly constructed. I ended up going with a Stant Superstat (OEM temp) and it's been great. Temps are very steady and it's coming up on 5 years since I installed it.
07navi
And the point?
Not saying all aftermarket ones are bad but they need to be made correctly for these engines. My Motorcraft one was fine the whole 12 years I had my last truck.
762mm
Quebec, Canada
Under these conditions, I'd do the following fairly cheap solutions, in this order and see if it helps :
1. Check proper coolant level.
2. Change thermostat.
3. Flush heater core.
4. Replace temp sensor, or at least make sure electrical connection is clean on it. Check connector and wiring.
4. Remove and inspect water pump. The Ecoboost have plastic fins in their WP, I believe. Those are known to break off sometimes, thus you could get no coolant circulation.
5. Inspect truck's computer to see if it's not gone bad, thus generating false readings.
ManUpOrShutUp
And the point?
The point is that I would not recommend a Motorcraft. What did you sue for those 12 years to monitor temps that lead you to determine it was fine? Just curious.
07navi
All good 12 years and everyone in my last forum used them. Stant is a top brand so they should be OK too.
TobyU
And the point?
Point is be careful with newer motorcraft as there have been reports they are not nice and solid and don't feel like the oems that people are pulling out to replace after 8-12 years.
They may or may not operate the same or for the dame length of time as the original.
They are made by someone for Ford and in a few years they may be made by a different someone.
I like Stant also although fewer places around me are carrying them.
Murray are cheap and even thee best one is junk and short lived compared to original.
dlcorbett
dlcorbett
Air Force
tx
Sorry about that, she said ford told her that she needed to get a computer part replaced, i cant remember which one. It sounded weird to me, i think something about the throttle body. Its been fine ever since though.
TobyU
I'm sure as long as the ford dealer made $300-800 they are happy. Regardless of what really needed to be done.
762mm
Quebec, Canada
Lol, so damn true... that it hurts!
Unless I am mistaken, throttle body position sensor or motor should not trigger cooling system fault codes. Perhaps the battery was changed recently and the TB needed the "re-learning" procedure to be performed (which is essentially to clear the ECM memory and let the truck sit idling for 20 minutes).
Oh well, we'll never know I guess. Ford dealers gotta make money too, I suppose.
coolzzy
Idaho
Look in the F150 forums, this is a common issue with the gen1 ecoboost trucks, which ours is based on. I've had it happen to me twice where I'll be towing up a grade, plenty of power, Temps all normal, and then the engine temp will spike to max, a reduced engine power alarm flashes on the display. As soon as I let off the gas, and I mean instantly, the engine temp drops to normal and message dissapears. Lots of theories, but most common is an ecu failsafe that is triggered prematurely to protect the motor when the turbos are hot. The way around it is to drop a gear or two to reduce boost and stay under 60mph on the hills when it's real hot. I do this and have never had it happen again.
TobyU
Oh here I go....
And how many of the old V8s did this???
Now they will get the think tank together and come up with a fix or workaround or at least an improvement for newer ones...
That would have never been needed had they stayed the course of tried and true..
But yes, keep reminding me that new and new tech and fresh and cutting edge sells.
07navi
I think the limp feature isn't perfect. My 2000 V-10 went into limp mode, it wasn't even hot, and the gauge went from 3/8 max to pegged instantly. I put a Motorcraft thermostat in it, it has been fine ever since, and that was 6 years ago.
Plati
And the point?
It's pretty much self explanatory.
