Radio problem
mijoedoc
Tennessee
I have a 2020 Platinum and the same SiriusXM problem started recently. It works with first startup of the day, but then does not work on next startups. All other sources work (AM, FM, USB attachments...). Another site suggested Ford is aware and there should be a SYNC update coming. Another suggestion was a soft reset (press and hold FFW & PLAY). Have not tried it yet, but this is very frustrating.
tommyddsr
Portsmouth, Va
Not trying to be funny but your trial subscription didn't expire did it? When the subscription expires you get one station for advertisement and teaser, and tuning doesn't go to any other stations.
mwl001
Scottsdale AZ
I’m having this problem too. It seems to be related to how long the vehicle has been shut off. When I stop for gas, that’s not long enough and the satellite freezes (song and station do not update or play). But stop for longer (haven’t tested but overnight always seems to work) and it comes back. Not related to plugging in a phone or CarPlay from what I’ve seen.
Go2rjm
Va
I am having the same issue on a 2020 Expedition Limited Max. When I stop the car and shut off the engine Sirius XM becomes unusable. I plan to update the SYNC software to see if that helps.
Fastcar
Army
FL
Ford put a new update for Sync a couple of days ago. You can either download OTA or to a USB and stick it in, a much quicker way.
Go2rjm
Va
I spoke with the SYNC3 representative and they confirmed that users have been reporting this Dave problem with the latest update. SYNC3 v3.4.21194. They recommended not upgrading if I had a prior version number. There is no estimate on when the next release will be available. After I posted this, I saw FASTCAR message that said SYNC3 just put out an update a few days ago so I assume it is the one I posted above. I will update and see if the fix is in.
Fastcar
Army
FL
The update for SYNC 3.4 that was installed was build #21194. That seems to have taken care of the "travel link" issue thus far. Rob6805 has installed it as well and was happy with it. I have noticed that it takes about 3 minutes for the Travel Link to populate. This is a fairly large download so it may fix a few things.
Fastcar
Army
FL
Curious, how did you get hold of a representative?
