NorthWestYuppie
Posted pics are of the vehicle running with lights off.
I literally taped in place I was too lazy to remove grill. I’ll post picHow did you do the grill? Did you remove or tape well. Etc?
Really want to do this on mine!
Because removing the grill is way more pain in the rear than it should be. I need to remove mine to replace the front camera sprayer and have the instructions all printed out, just need to find the time.I literally taped in place I was too lazy to remove grill. I’ll post pic
GixxerJasen: You wouldn't be able to share those instructions, would you? I've tried a couple of times, as I need to replace my front camera, and always get stuck around the time to disconnect the front bumper cover from the frame.Because removing the grill is way more pain in the rear than it should be. I need to remove mine to replace the front camera sprayer and have the instructions all printed out, just need to find the time.
Check this thread:GixxerJasen: You wouldn't be able to share those instructions, would you? I've tried a couple of times, as I need to replace my front camera, and always get stuck around the time to disconnect the front bumper cover from the frame.
Still holding up. Got a little too close with power washer in one area. Will fix in summertimeLooks great, how is it holding up?
Thanks
