Spare tire questions from a Ford noob
sharat
Katy TX
Hi y’all
I bought a new ford expedition 2023 last October. The first time I ever had to use the spare was on a the last Memorial Day where my main tire was losing air (found out a nail when swapping the spare). When the spare was mounted we had 45 psi. But after driving a few miles the spare started leaking air. Both TPMS and Manual gauge (at a local gas station) showed low psi on the spare.
When mounting the spare I noticed that the side wall of the spare looks shaved and
The spare is also the same size and dimensions as the main tires.
A few questions as a newbie to Ford.
1. Will TPMS work for spare tire ? I am guessing not, but when I mounted the spare I saw the spare show 45 psi myself and then it started going to down under 35 (red flag) on the dashboard
2. Since the tire size is the same as the main tires, can I drive at regular speed or should I use the guidelines as that of donut tire?
3. Is it safe to use a spare tire that looks shaved on the side wall and worn out.
When I went to the dealership today asking questions, they assured me that it’s absolutely usable and shows a healthy 40psi.
I am just concerned about our safety when on road.
I’ll keep this forum posted on my experiences as I get into 4th July holiday travels
Thanks in advance for guidance.
Sharat
TheDoug
Mansfield, TX
There is no tpms on the spare. You may have been picking up the old tires signal that you took off.
I drive normal speeds on my spare when I have had to use it. Like you said, it is the same size as the other tires.
Now this shaved side business I don't know about mine was totally normal looking. You have a pic of what you are talking about?
Left Coast Geek
Mid Left Coast
yeah, the spares I've seen, including mine, are standard 18" tires on a steel wheel. Mine is a Hankook Dynapro HT, 275/65R18 (and my Expy came with 22's)
2020-MAX-Limited
Colorado USA
Last summer I got into the spare tire situation after owning our 2020 for 9 months. We were planning a road trip and I just wanted to get familiar with the tool and tire situation, so I lowered the wheel / tire to inspect and top-off the air. As you can see, our 2020 has 265 / 70 R 17 on steel wheel. I topped the air up to the max 51 psi. Just wish I had a better pic of the DOT date code because it looks quite weathered in these pics. Maybe next time.
BTW, if you do the math, the spare (265 / 70 R 17) is 0.3 in. shorter in diameter than the main (275 / 55 R 20). That gives a 0.96 in. shorter circumference. Less than 1 inch per rotation shouldn't affect ABS or Stability systems, I would think.
This post is a good reminder for all to become familiar with the emergency equipment and procedures of your vehicle.
Alwaysthinkin
Army
Georgia
Was your spare balanced? Mine wasn't.
TheDoug
Mansfield, TX
Wow my spare is a different size... like Left Coast Geek said... mine is a 275/65r18 which is 32.07" (the stock tire is 32.10")
however your spare is only 31.61" which to me, is big enough difference not to drive far as its 1.3xx% smaller
2020-MAX-Limited
Colorado USA
My stock main tire is 275 / 55 R 20, which is 31.91 inches tall, not 32.10, so it's closer to the spare size of 31.61 inches. Maybe you have a different size main tire?
Still, I agree with your recommendation not to drive any farther than necessary on the spare, if ever needed.
TheDoug
Mansfield, TX
I do... 285/45r22
I thought all trims were closer together in tire size
My bad
I drove from Dallas to Houston on the spare once and had no issues. Since then I have put a 22 inch rim with same tire size in the spare spot.
duneslider
Utah
I unfortunately have used my spare a lot more than I would have liked. That included a few hundred miles while towing and have not had any issues with it. It doesn't match the others but it works fine. Also, neither of the expeditions I have owned have TPMS on the spare. My jeep commander did have tpms on the spare and would register when placed at one of the 4 corners. I was actually kind of surprised the expedition didn't have this.
CDNRabbit
Ontario Canada
I too got to test out my spare this weekend. Can confirm there is no TPMS, tire is not perfectly balanced but very usable. Towed a few hundred KM without issue. Glad to have a spare and not repair kit like most cars these days.
Mine is a Crosswind 275/65/R18 A/T
Samantha1
I had to use mine on vacation last month. I got a side puncture in Dallas on my way to Santa Fe. I couldn't find a Toyo Open Country H/T, so I called the Ford dealer in Santa Fe and had them order one. No issues with the spare - a Goodyear Wrangler. Both are what came on the Expedition.
Samantha
ROBERT BONNER
Denver, NC
Ford doesn't balance spares. On other threads on this forum I have advocated getting your spare balanced and "flipped" so that the wheel faces down, making checking and filling the spare much easier. Thankfully they are still delivered with fully functional "near size" tires. My '22 KR PowerBoost F150 FX4 came with a temporary spare. Imagine losing a tire off road and having to depend on a tire with 3/32" tread depth to get back to civilization....That got replaced.
Alwaysthinkin
Army
Georgia
The fact that Ford doesn't balance spares was a surprise to me. This is my first Ford so the lack of a balanced spare, not to mention the "split" lug nuts, were news to me. I even mention these things in my signature line as my way of hoping other Ford newbies take note.
I flipped my spare, which was an aggressive tread tire, not even close to the Hankook's my vehicle came with until I saw this idea in another thread.
I put this hose on and routed to behind the license plate area and now I can check the spare without having to get on my back under the vehicle. I keep intending to look into routing it into the area where the jack is located but haven't followed up. The wheel faces up so the side that shows when in use is protected.
Boosted
North Jersey
As much as I love the remote fill idea, I'm concerned about the tire Schrader valve being held in the open position for extended time and then having a leaky valve when needed. Make sure to bring a high quality valve cap with you that could prevent an issue.
Are there remote hoses that do not depress the valve stem?
jjscsix
texas
The differences in O.D. that some of y'all are talking about is no bigger differences than the tire gets as the tread wears down.
And I’d like to see what the “sidewall looks shaved down” means and how it happened.
lobsenza
I have used a hose on spare tires for years. I have never had an issue with a Schrader valve leaking after a hose is attached.
ROBERT BONNER
Denver, NC
I led in a variety of roles at Ford over 23 years. My last job included, among many other things, all of the Truck and SUV wheel and tire machines and the associated processes. I'm unsure of other manufacturer's policies; but, Ford did not balance spares for the same two reasons that were used on anything that didn't affect safety, compliance, warranty, long term durability or measured customer satisfaction: Cost and weight. To balance a spare would require additional cost and weight. Many customers go through their entire ownership experience without using a spare, so, relatively few are ever affected. Factor in customer sensitivity to balance (even ability to mount their own spare) and the number of affected customers shrinks further.
In Kentucky Truck Plant where both SuperDuty's and Expedition/Navigators are produced, they have to mount, inflate, and balance a wheel/tire combo every 6 seconds. When I was in charge nearly 20 years ago we were running that plant about 112 hours a week, 49 weeks/year. 20 years ago, we could pull VIN specific data for years that listed serialized wheel, tire, weight, pressure, etc. of all assemblies for quality containment reasons. The completed wheel/tire assembly was all done with virtually no human contact. Think about that the next time you're sitting in Discount Tire watching them mount a new set of tires for your Expedition. It's a fun process to be involved with. People talk about high tech....that's high tech.
Probably more info than you wanted...
All that being said...I only drive them now. I engineered a spare wheel/tire combo (balanced) that stows and functions for my '12 GT500 because it came without a spare (!). I bought a right sized off-road suitable spare (mounted on stock spare wheel and balanced) for my '22 F150 FX4 to replace the temporary (virtually tread-less) spare that it came with (criminal). The '20 Expedition only needed balancing and flipping. The main reason for the orientation of the spare from the factory is a virtually imperceptible reduction in escape angle combined with increased visibility of the "hidden" spare, which styling did not like when the tire is secured face down on some vehicles.
Alwaysthinkin
Army
Georgia
Interesting information, thanks for sharing.
Not surprised that cost savings is one of the driving factors for not balancing spare tire. However, what continues to surprise me is Ford has made it clear, in my opinion, customer satisfaction is well behind cost savings. There has to be a better middle ground with customer needs being met then I am seeing from Ford. High customer satisfaction means high repeat business and that should be the long view from any company who intends to remain in business. Take that along with the incredibly poor customer service at Ford Dealerships in my area I'm unlikely to buy another Ford down the road. In the spirit of teaching an old dog new tricks, my experience has shown me the quality of the Dealership is more important, the vehicle choice is secondary to that decision. Meaning, I'll be shopping manufacturers dealerships in my area first and vehicle second. Having said all that, I'm extremely happy with my Ford Expy. I have not encountered (knock on wood) any of the issues so many forum members describe in many posts. Of course my 2020 is extremely low mileage compared to most.
No members online now.
lanzarote wayne
