Is that something Ford premiumcare would cover u think?Looks to be the coolant lines that feed the transmission heat exchanger.
JL3Z8A519D - $41.17
JL3Z6A715C - $112.33
I think they should.Is that something Ford premiumcare would cover u think?
Indeed we will see! Ill update this after dealer has looked at it on the 25th thxI think they should.
You can't drive it but the dealer can't look at for 10 days? Try another dealer. Where in Mass are you?Indeed we will see! Ill update this after dealer has looked at it on the 25th thx
Theres no Ford dealers in my area that can take it before the 25th. Im on the northshore/Peabody area. Every time I make an appt ( for anything) they are weeks out . Just shows that the service departments are always swamped because of the trash quality of ford vehiclesYou can't drive it but the dealer can't look at for 10 days? Try another dealer. Where in Mass are you?
Yeah, don't count on the ESP warranty covering the hoses. At the bottom of their PremiumCare brochure it lists those item not covered and "hoses" are listed under the 'Repairs Related to Your Maintenance Requirements' and are not covered under warranty. But, can't hurt to ask/insist.Good luck, those are the cheap hoses. Don't hold your breath as many here have been told that coolant hoses are not covered. If they cover it, throw a party.
Yea, they for sure wont cover. I just hope its not crazy expensive.Yeah, don't count on the ESP warranty covering the hoses. At the bottom of their PremiumCare brochure it lists those item not covered and "hoses" are listed under the 'Repairs Related to Your Maintenance Requirements' and are not covered under warranty. But, can't hurt to ask/insist.
What do you consider "Crazy" expensive? Is $1200 crazy expensive when they coulda just used worm gear clamps instead?Yea, they for sure wont cover. I just hope its not crazy expensive.
Anything over $50What do you consider "Crazy" expensive? Is $1200 crazy expensive when they coulda just used worm gear clamps instead?
Thx for the post.My dealer quoted $700 plus for the heater core hoses. Did them myself and in an hour or two and saved hundreds. I can't imagine it would be much better for this situation.
