I had the cupholder/shifter section lifted up to run some charger wires, and noticed this button towards the back driver's side.
From the console side, you could press it towards the front and it will spring back as if it is a reset switch. However there is no access to this without pulling up the cupholder piece.
The wires are at the end of a Y with the other leg running up to the Park Sensor / Park Assist buttons.
I searched around but couldn't find any part numbers or online references. Any ideas?
