Was driving home last night when the truck lost power (2003 5.4L - 4WD), stumbling, and wouldn't go anywhere when given gas. I had my code reader in my truck so I got the following lean codes:
P0171, P0174
I shut the vehicle off, and after several minutes, restarted and it would drive enough to get me off the road. I did a visual inspection and there was nothing obvious. I ended up limping it home by shutting off the engine and after it sat for several minutes I could drive for a minute or so at a time before it would eventually stumble to the point that it would not accelerate. Fortunately I was only about 7 miles from home so I eventually made it back without having to call a tow truck. I'm not sure why letting it rest for 3-5 minutes mattered but it did. Once I got home and started checking things out it also spat up an additional code: P2195 (02 sensor signal biased/stuck lean bank 1 sensor1)
When I get off work I intend to start with the MAF sensor, checking responsiveness and cleaning it. I checked for vacuum leaks last night with a squirt bottle but intend to revisit this with some propane.
I know it could be quite a few things but plan to start there. I'm including the freeze frame data in the hopes that someone sees something that jumps out at them. I appreciate any insight into this.
Thanks!:
FUELSYS1 CL
LOAD_PCT% 67.1
ECT(F) 199
SHRTFT1 46.1
LONGFT1 24.2
SHRTFT2 47.7
LONGFT2 23.4
RPM 1926
VSS(MPH) 66
SPARK ADV 20.5
IAT(F) 105
MAF (LBS/S) .10
TP% 34.1
O2B1S1 .635
SHRTFTB1S1 46.1
O2B1S2 .575
SHRTFTB1S2 N/A
O2B2S1 .10
SHRTFTB2S1 47.7
O2B2S2 .570
SHRTFTB2S2 99.2
P0171, P0174
Thanks!:
FUELSYS1 CL
LOAD_PCT% 67.1
ECT(F) 199
SHRTFT1 46.1
LONGFT1 24.2
SHRTFT2 47.7
LONGFT2 23.4
RPM 1926
VSS(MPH) 66
SPARK ADV 20.5
IAT(F) 105
MAF (LBS/S) .10
TP% 34.1
O2B1S1 .635
SHRTFTB1S1 46.1
O2B1S2 .575
SHRTFTB1S2 N/A
O2B2S1 .10
SHRTFTB2S1 47.7
O2B2S2 .570
SHRTFTB2S2 99.2
