fisherman1
Hi I just purchased a 2006 expedition Eddie Bauer edition. I removed the drivers seat and replaced the seat covers . when I hooked everything up and tried the power seat the seat was going back twisted one side of the motor was not turning the track screw. I stopped immediately and tried the tilt button which worked . inadvertently I pressed a seat memory button then everything shut down. I checked the fuses #3 and #109 which were good, I checked the cable connections and they are fine. I do not have even a manual movement when using the side switch. All I hear when manually trying to move back and forth and up and down and the pedal switch is a clicking from the memory control module under the seat. When the memory button is pressed from one to 2 the only thing moving are the mirrors. the seat and the pedals do not move manually or from my memory setting. I disconnected the battery and after 10 min reconnected it to no avail. Any advise would be greatly appreciated. Thank you Dino
