SteveIdaho
My 2014 Expedition (107k miles) was in the shop a couple weeks ago to replace four struts and install new front end stabilizer links.
After getting the car back, I've got a front end grinding noise in 2H that lasts less than a second under light acceleration, typically 15 - 25 mph. I figure this is an IWE problem with a vacuum line leak. The reduced engine vacuum during acceleration is causing loss of vacuum in the front hubs, causing the springs to slowly engage the front hubs.
The noise does not happen in 4A (vacuum is released and the hubs are always engaged). I've been driving in 4A since getting the car back.
Yesterday we did two freeway trips in 4A, each about 35 miles on the same freeway, one east-to-west and the other west-to-east. I reset the mileage computer when entering the freeway both times. We got 18.2 mpg on the freeway both directions.
2. Is it worth having the IWE repaired so 2H works properly? (ten year old car with 107k). I don't have a quote yet to repair it. It might be as simple as re-attaching a disconnected vacuum line to the hubs, replacing vacuum lines in the IWE system, or replacing the solenoid and check valve.
If I drive the car another 50,000 miles, get 15.8 mpg average highway / in-town, suffer a 5% reduction in mileage, and gasoline costs $4.00/gallon, I would pay an extra $680 for fuel.
If I suffer a 2% reduction in mileage and gasoline costs $3.50/gallon, I would pay an extra $245 for fuel.
I don't like broken things, but it is hard to justify a big IWE repair bill.
QUESTIONS:
1. How much mileage reduction is typical when driving in 4A vs 2H?2. Is it worth having the IWE repaired so 2H works properly? (ten year old car with 107k). I don't have a quote yet to repair it. It might be as simple as re-attaching a disconnected vacuum line to the hubs, replacing vacuum lines in the IWE system, or replacing the solenoid and check valve.
