3rd row seat not folding
dgq68
Hi, in my 2022 SPP Expedition Max, the passenger side 3rd row seat is stuck in the reclined position and won't fold. The driver's side seat works without any issues. When I hold down the forward button in the third row or the fold button near the rear gate, I hear a clicking noise but nothing happens. Anyone know a fix to this? I tried holding down buttons for a minute, but nothing seems to make a difference.
Thanks in advance.
Donny
2020-MAX-Limited
Colorado USA
Are you trying this with the car off? One time, mine didn't go down until I started the engine and then it worked. It could be a weak 12V battery.
D
dgq68
Car is off, but the other side is going down. I can try with the car on and see if it makes a difference.
99WhiteC5Coupe
Tried it with the car running and made no difference.
There have been some posts on this forum about this issue on the 4th generation models. The fix seemed to be repositioning a seatbelt buckle that was supposed to fold aside or down?
Have you checked your seatbelt buckles, and under and alongside the seat to see if there is an obstruction?
D
dgq68
I moved buckles and don't see anything under the seats. Still not working. I hear clicking but no movement. Is there a way to reset it?
D
dgq68
My 13 year old son found a solution for this so figured I'd share in case anyone else runs into this issue in the future. To unfreeze the seat from the reclined position, he hit the recline button (in the 3rd row) three times and then the move forward button 3 times and held the forward button on the third time until the seat moved forward. After this it started to work with folding and unfolding again. Not sure if it'll last forever or not, but at least there is some sort of fix for this. Hope this helps someone else who is as frustrated as I was.
FryerTime
Hopkinton, MA
Mine has been to the dealer a few times for that and it's a real pain when those stop working. First time there was a crayon in the track so it wouldn't decline. Second time it was stuck down and apparently one of the harnesses under the seat had come disconnected which was surprising knowing how difficult those are to disconnect. I do tend to store stuff under the seat though which the dealer advised against.
Toni Halik
Chicago
Thanks in advance.
Donny
Toni Halik
Chicago
Hi, I just fixed this problem for my expedition 2020
1.There is one fuse to both sits in the third raw - if one sit works, you got power to other.
2. Listen carefully, under the sit while pressing down fold. Do you hear clicking? That motor trying to start.
3. Look under the sit, there are two motors- one per side. Tap gently motor brackets with hammer. I am not sure what exactly happened, but during tapping my wife was pressing on/off sit switch and the sit stared folding.
4. If motor starts. Please stop immediately and send the sit back to upright position !!!!!
5. Now true root cause::::
Examine the seat belt buckle location. In my case, it was bend away from the sit and it stopping sit movement.
6. Solution: I used small bungee cord to keep buckle at all the time against the sit and to follow the sit when moving.
I hope some of it will be useful
Rudy Lozano
Maine
I've got a 2021 Expi Max Limited and since 5K miles (prior owner, dealer service records) it has been an issue. we have replaced the switches, seat frame and both motors to no avail. the dealer consistently says its fixed and when I go to pick it up the same issue.
when I try to raise the seats (normally down) they raise part of the way or all the way including the extended recline and won't go back down. We travel with 3 German short hair pointers, not having the 3rd row reclined doesn't work for us. the next step is some controller module.
Christina S
Florida
Hello, I'm new to the forum. I own a '24 Plat with 445 miles, bought Nov '24. The 3rd row seat (driver side) would intermittently work then finally stopped working. Dropped it off at the nearby Ford Quick Lane at the dealership. They replaced the switch assembly first and that didn't fix it. Next, replaced rear seat back retaining, headrest guide sleeve, head rest assembly, and foam pad. I checked the online prices for each and they're reasonable EXCEPT the rear seat back retaining. Relieved it's under warranty.
Was losing patience because it was at the shop for almost 2 weeks and most of the wait was due to the delivery of parts. They didn't have a loaner to give me. Good news though: picked it up today and everything works fine. Just sharing my experience so it might help others.
