99 expy 5.4 2v
watsonj8
Florida
Just replaced head, battery, starter, and IAC. When I crank it now it sounds like the starter stays engaged. Anyone have any suggestions on fixing the problem. To give a run down, I had a time getting it into timing. Then the starter burned out and battery went dead. When i finally got it to crank it was shutting off when idleing. So I replace the IAC.
LameSuburbanDad
rockwood, MI
did you disconnect the battery wires from the solenoid mounted high up on the firewall?
if so are you sure the wires are back the right way......
I know the wrong configuration could make the starter stay engaged after the truck has caught fire.....because it happened to me.
