blinking air bag light
dkenney1
ann arbor mi
hello, this is my first time trying this so I hope I do it right. I have a 2005 eddie bauer and when I start the truck the air bag light blinks 4 times then 2 times until I put it in drive then it stays on. I seen on line that it might be the left side crash sensor but I'm not sure and I don't know where it is located.
B
bedrck46
if the light is flashing 4times then 2 times if I read the manual correctly it indicates the following
42 Restraint System — Impact Sensor Status (Front Impact Severity Sensor Circuit Fault)
other than that I have no idea what to advise you
Depending on your experience you may want to get a copy of;
Ford workshop manual on DVD. Can be obtained from seller "morpheousking" on e-bay. Cost about $15.00 Much better than Clymer, Haynes or Chilton and also includes wiring diagrams
Don't waste your money on a Clymer, Haynes or Chilton Manual.
It is well worth the $15.00 just make sure you get the DVD for your year as the seller has different DVD's for different years
B
bedrck46
You may not want to attempt any repairs or adjustment on the airbag system unless you are qualified and experienced in this area
IMO this is one thing I would leave to those that work on these systems
