Blower motor questions
garden city mo
My wife’s 2018 expedition max limited has started to have this problem with the fan being on high and not blowing at all or very little. The blower is still working but no air out vents. I bought a new blower motor resistor but can’t find it for the life of me. I’m really needing someone to point in the right direction of this car. We have had nothing but problems for this past year. We love the car for the size for the kids but it’s starting to become a pain.
99WhiteC5Coupe
Have you checked the plastic HVAC blower case, under the glove compartment? Usually the blower resister is attached to the case with one or two screws, and has a wiring harness connected to it.
Y
garden city mo
I took it apart down there underneath and it doesn’t look like the same part I have. I know the one I got is right according to orielys and what I’ve found on the internet
99WhiteC5Coupe
You may have gotten the wrong (aftermarket) part.
I would locate and remove the old part, to determine the part number, then buy a Motorcraft part.
Y
garden city mo
From the pictures of the motorcraft and new part look identical. i researched the heck of this and have come up dry everytime. there is a ton of info on the older expeditions like 15-17 but 18 to the present there is super little info on them
GlennSullivan
NY & FL
Is this the part you are looking for? If so, Ford refers to it as a "blower motor control module".
HVAC Blower Motor Control Module - Ford (G3GZ-19E624-A)​
Rock Auto - Motorcraft - Multiple views available on this link.
Tasca Parts
GlennSullivan
NY & FL
Ford’s system thinks that is the correct part.
Can you post a pic of the actual part that is in the vehicle?
Y
garden city mo
I would but I don’t even know which one it is. Didn’t know if it was behind anything or had to take other pieces off to get to it. I guess I’m looking more for the location of that part. I didn’t take picture of it had it tore down the other day. Was more frustrated it wasn’t right in front of the blower motor.
Wangle
Des Moines, IA
Is the cabin air filter clean? Simple, I know, but I had my son-in-law not change his for over 100,000 miles! True story…
2010ELExpy4x4
California
Limited probably has dual zone I believe module in different location than standard, which is at bottom right side of blower box
chris451fmc
usa
I have the 2017 Expedition with tow package and 4x4. The blower some times will not come on. I can stop, go to the passenger side and wiggle the wires under the kick panel and it will start going again. So there is a bad connection there. I have an IR camera and I could see the two large wires going into a white module on the side of the blower case were hot as well as one of the many connectors under the dash, a couple of larger wires get warm from the amperage of this blower, and I think the real problem is connector contacts that get hot, melt or reflow the plastic in the connector, and cause an open circuit. Maybe since I tug on the wires in that area I clean the contacts on the blower motor connector. I have not done a recall for hot blower motor yet. A connector with high amperage can get hot enough to ignite the plastic in the connector if its got bad contact. I need to know what exactly they are replacing in that recall.
GlennSullivan
NY & FL
There is a recall on the blower motor, which Ford will replace at no charge. there are also issues with the controller /resister, and possibly the harness. If it turns out you need either of the other items and do not have an extended warranty, you will be charged for these.
Clink on the link below and put in your VIN. The open recalls will come up. Note as I said the controller and harness are not recalls and will not come up.
Link To NTSB Recalls
Dahammer
We recently had a problem with our station car blower motor. The only setting was a high fan setting. The mechanic installed an aftermarket resistor, but that part didn't fix it, so he ordered one from Motorcraft. That solved the problem.
Dahammer
You may have to expand the photo to see where its location is. Sorry about the clarity of the photo.
