Ok I got the LED strip light installed. I didn’t use the multimeter correctly and when I went to test the amps of the existing bulb I popped the fuse. Unfortunately I didn’t have any spares so I had to go get some. Got home and inserted the new fuse and made sure I didn’t mess up anything else. Which I didn’t. So I took the fuse back out and then accessed the wires in the console. I took the lid off and then the cover behind the lid that has the 2 cup holders in it. Once I did this, all the wires between the interior of the console and the back it were accessible. The most difficult part was getting the 12v power supply wire adapter unplugged. After it was out of the way it made working in there much easier.
I found where I wanted to run the wire from the LED’s into the back and drilled a small hole about 1/8” in diameter just big enough to feed the wires through. Its in the upper back left corner just under the lip of the console. From there, I cut the existing bulb off and wired up the new LED’s and then put the fuse back in and the lights worked. I took the fuse back out and made a good connection of the wires with butt connectors then taped everything up and mounted the strip under the lip along the driver’s side of the console.
Then I put the fuse back in everything was good. I tinkered with the light and the switch that turns it off when the lid is closed. I left the light on for awhile and made sure nothing was heating up. All was good so I put everything back together. I made a little video of me hitting the switch and the light in the console. This was during daytime so it isn’t nearly as bright as at night. I forgot to take photos of everything else I did. Overall I am satisfied with how it turned out and it illuminates the console much better than the stock bulb. I need to put the original bulb back in to cover the hole but its a little tricky getting it in there. Thanks for yall’s input and help!
Edit, for some reason it isn’t letting me post a link to the video. I’ll work on that.
https://imgur.com/gallery/wHNmuw2
