2019 led strip dim
sixsix
Louisiana
Just noticed the passenger side led trim drl is significantly dimmer than the drivers side. I’m guessing the only fix for this would be a complete headlight replacement? Also noticed a coolant leak on the passenger side, my ‘15 ended up doing the same thing and it was the heater hose. I can’t find the drip point to save my life but it’s obviously leaking from somewhere.
arock
Maryland
Could check the connector to make sure its clean and getting good contact. If you have a multimeter you could check the voltage coming in and compare to the drivers side to make sure its getting the correct power.
Mr Big
Tampa Bay, Florida USA
I just purchased a certified pre owned platinum and it had the same passenger side issue. They had to replace the entire headlight.
I'm fortunate they replaced it for free, since I noticed it before taking possession.
