Deciding on 3/2 Lift for 08 EL
valenrandy
Houston, Tx
I went ahead and purchased a new set of rear struts/springs to replace my air suspension and also got some new front struts. Before I get on and install them I figured it be a good time to decide weather I should get one of these spacers/ 3/2 lifts they sell on amazon or ebay.
I have been reading that ride quality is not changed and all it does is give you a mild lift while leveling the expy out.
Is there any other item I need to be aware of regarding the installation of this type of lift?
Has anyone experienced any difficulties during install or after the lift being installed?
I just want to have an idea if this will compromise anything in the future.
Just looking for a Pro's/Con's
Thanks!
J Ski
3.5plati
VA
Readylift seems to be rather popular. I will be purchasing their 3/2 here within the next few months for my 2016
V
valenrandy
Houston, Tx
Good deal, I was just asking to see if anyone had any problems after installation or things I could see down the line as a result of the lift.
BTW, prices are all over the place from around 99$ to 400$ for what looks to be similar items. Some look like metal and other look like a kind of plastic resin.
Thanks!
Rigpig
SW KS
I just found a great deal on a ReadyLift kit on fleabay for $240 for the 3/2 kit. I looked at the $99 kit, but some of the negative reviews scared me off. Some mentioned cheap metal and bad welds, so I shied away from them because my Expy will regularly be transporting my family with two little girls. I had talked myself into the ReadyLift kit because AutoAnything had one of their 20% flash sales yesterday, so that made the kit $320 with free shipping. I was going to wait for another flash sale that they seem to have every other day, but fell wallet-first into this deal. I'll probably install the lift with my bald 265s and XLT rims to get a good measurement on what tires will fit. I'd like a little more aggressive offset, and am looking at 20x9 +25mm offset wheels to tuck a wider tire. Not sure 35x12.50r20 will fit on that combo. Might either go with a 35x11.50r20 or step down a size to LT295/60r20.
ETA: I have installed a number of leveling kits on everything from my Tundra, to a couple F-150s I've had to a 3500 Dodge Cummins. They are very simple to install, and only take around an hour, probably less if I sit the beer down. Front and back I'd could foresee taking up to a few hours for a first time installer. Shouldn't need any special tools. Likely just a good floor jack, a set of stands and some basic hand tools. Power tools would shave off a ton of time. I've never had a spacer kit cause an undue amount of wear on anything, but I don't really beat my vehicles too hard off road. I've always been able to get alignments within spec with stock components as well.
V
valenrandy
Houston, Tx
I did see those yesterday on fleabay! I will probably get those and install them when I install the new front and rear suspension. I'll have to ride on my current tires before I can justify new wheels and tires though. I have Hankook Dynapro ATM RF10 275-65-18 that I got last year and they ride and handle great! Still have plenty of life left on them also.
limitedex
Ok
OP,
Just use your OEM air bags in the rear and change out your air bag "sensor" which tricks it into thinking it needs to compensate for weight on the rear. That's what I did. There's a write up on here somewhere.
V
valenrandy
Houston, Tx
I did see the write up but I have already purchased the replacement parts for the air suspension. It was a hard choice but I am at peace with it now lol.
Bronco635
Va
So I'm looking at the readylift 3/2 also.
Who out their is running this set up? Got any pics? What the side effects of running it? Will i need another alignment ? I defiantly want to keep my ride quality in tact if possible.
I would like to run only a 33x12.50 tho.
Menard LaDouche
Nevada
I did the Ready lift recently (Fat Bob, $240). I also increased the tires to 275/70/18 (F150 rims) and went with Hercules 10 ply rated AT tires. I love the ride, especially the off road performance. Very much better. Gas mileage about the same (18.1 mpg on recent 1000 mile trip with 300 miles off-road). Ride feels slightly different, but nothing the family has noticed. It is nice sitting up higher too. I have 2 1/2' clearance in the wheel wells all the way around, despite the optics of the photo. I did an alignment after the lift install. Despite the claims that this was a 3/2 lift, it is more like a 2/2 lift. The actual spacers are 1 1/2" all the way around, so that is what you get all the way around.
Rigpig
SW KS
I got my ReadyLift 3/2 on. I'll post pics when I get rims and tires, it looks like garbage with the stock XLT rims and bald 265s. Like a little kid at Christmas, I tore into the box and threw the lift in without taking measurements of the stock configuration. Eyeballing it looks like the amount of lift is true. I will say that at 6'2", I had to slide down into the Expy in stock form like a car. Now I have to use the running boards like a proper truck.
It's an extremely easy job, putting the lift on. I've put leveling kits on late model F-150s before, so the front was a cakewalk and took less than an hour. The rear was even easier. Maybe took 2 hours beginning to end for front and rear. I'm extremely happy with the kit. I wish we could get more lift out of these trucks without having to spend $3800, but it is what it is. I would advise getting an alignment done when you are finished, it's a whole lot cheaper than a set of tires.
V
valenrandy
Houston, Tx
Ok, Readylift has been purchased!
Now I just need to find some time lol.... I'm sure it will look funny with my stock wheels/tires but I think I found a good deal on some 17in raptor wheels with K02 tires 315/70/17.
Will that tire fit ok with the 3/2 lift?
Thanks.
Rigpig
SW KS
Thanks.
From research I've done, as I was leaning towards Raptor wheels initially, you'll have to trim the ends off of your CV/spindle shafts on the rear. Doesn't take much, and a 4-1/2" grinder with a 5" cutting wheel would make quick work of it. The tires would likely rub on at least the front valance and fixed running boards, so trimming would be in order.
No members online now.
Landsbutter
