carid
Looking to maximize your SUV's cargo space for upcoming trips? We've got the perfect solutions for you. Our Go Rhino SR Series Roof Rack offers a versatile and durable way to carry more gear. Its modular design lets you customize and expand the rack based on your needs, whether you're hauling camping equipment, sports gear, or extra luggage. Made from high-quality steel with a textured black powder-coated finish, it not only looks rugged but also resists corrosion for long-lasting use.
If you're interested in a cargo basket, the Go Rhino SRM 400 Roof Cargo Basket is an excellent choice. Constructed from heavy-duty aluminum, it's both strong and lightweight, making it easy on your vehicle while handling heavy loads. The aerodynamic design reduces wind resistance and noise, so your drives remain quiet and fuel-efficient. With integrated accessory slots, you can easily attach additional items like light bars or tie-down straps to secure your gear.
Both the SR Series Roof Rack and the SRM 400 Cargo Basket offer universal mounting, fitting most roof rack systems without the need for drilling or extensive modifications. Installation is straightforward, so you can hit the road in no time. We're here to help you enhance your SUV's functionality and make your adventures more convenient. Check out these options to make the most of your vehicle's cargo capacity.
Go Rhino® - SR10 Series Roof Cargo Basket
Note: Check "Product Options" to choose your specific model
Features:
- Installs over factory or aftermarket cross bars
- 48" or 60" Long
- Ideal for use with luggage bags or straps
- Side plate feature tie down points to secure load
- Tubular, mild steel construction - Black textured powder coat finish
- 5 year warranty
Go Rhino® - SRM 400 Roof Cargo Basket
Features:
- Galvanized steel fabricated panels
- Extruded aluminum cross bars
- Injection molded Nylon cross bar end caps attach the cross bars securely to the fabricated side panels
- Integrated side light mounts for standard cube stem mount LED lights
- Integrated hole pattern for standard scene light mounts - two sets per side
- Solid front fairing reduces wind noise while vented rear cover allows for air to escape reducing noise from turbulence
- Front fairing and rear cover are removeable exposing multiple mounting hole patterns for a variety of lighting styles
- Removeable front fairing and rear cover allow for storage of larger items such as paddle boards and kayaks, etc.
- Aluminum cross bars include a four-core extruded track system that works with any 1/4-20 hex bolt
- Universal U bolt style mounting clamp system included
If you want to learn more about the Go Rhino brand, please click the link below:
Go Rhino - About
This page contains all information there is to know about the Go Rhino®, the amazing products it creates, and the secrets that stand behind its success.
Browse the full catalog of Go Rhino accessories here:
Go Rhino™ | Grille Guards, Side Steps, Truck Accessories - CARiD.com
Turn your truck into the titan of the roadway with truck bed racks, side steps, hitch steps, storage cases, or any other heavy-duty parts by Go Rhino.
