Dropping differential???????
Funugy
Frisco TX
Anybody know how to drop this frickin thing??? I'm trying to drop it to get the cover off so I can replace the axles. Anybody know how???
2003 4x4 EB
F
Funugy
Frisco TX
Think I got the differential dropped. Anyone know how to get the shaft out between the spider gears. I've tried rotating the wheels but the end of the shaft will never come around.
pkuchirka
CA
Just looking at my mechanics manual. Take down spare.It says to remove drive Axel and there are some mounting bolts. Have something under differential to catch it. Move it forward and there should be enough space open cover.
I'm not sure 100% the procedures but the object is to remove spare and then move differential toward the front of vehicle
Sent from my HTC One M9 using Tapatalk
pkuchirka
CA
Mounting bolts on differential *
Hamfisted
Ft Lauderdale
I assume you're talking about the rear axle. There's a big circlip that retains the inboard CV joint to the differential side gear, accessible from the inboard side of the inner CV joint, between the pumpkin and CV joint. Using a special OTC tool (giant C-clip remover...) push the circlip out and slide the half shaft off away from the pumpkin. It's all done from outside the pumpkin. Should be no need to drop the pumpkin. You have to remove the wheel/tire assembly. Remove the outer hub from the shaft and flip the hub up out of the way. Do you have a Chilton manual or anything for the vehicle?
-Mike
Here's a link to the tool. You need the tool and the handle. About $200 worth ....
https://www.toolsource.com/misc-c-318/halfshaft-remover-p-99346.html
See if this PDF file opens for you, it should have the instructions in it ....
  • Expy Half Shaft Removal.pdf
