Out of all the books and articles I've read on the subject this is by far one of the best!!!
I always take what I read from mfg with a big grain of salt. This lays it out in an unbiased way.
PRESENT-DAY SUPERCHARGING - EXPEDIENCY OR EFFICIENCY? / AJ6 Engineering
I have read all the pro's / con's of all the variety of blowers including turbos throughout my years. Also have run a Centi... After running a roots for some time now I have come to the conclusion that the roots blower gets much more negative feedback than it actually deserves primarily due to the competitors exaggerated claims.
Roots blowers are actually fairly efficient
at low boost levels due to the fact they do not compress air internally. But as you increase the speed of the blower to try and make more boost it does hit a brick wall and becomes much less efficient. Correct size blower is also critical as with all makes for optimum efficiency. Roots blowers have improved through the years but the competition tends to quote the efficiency levels of early versions.
IMO...
Roots kept at 6psi boost or below would be fairly efficient and maybe the best choice between the different models as far as driveability. Beyond that your much better of with a twin screw.
Yes, I am overspinning the hell out of mine just to get 12psi boost or so and pushing it well beyond it efficiency range. But cannot afford a twin screw yet..
What surprises me is my IAT temps still are quite manageable. Typically 20-30 degrees above ambiant. A large part of this has to do with the efficiency of my intercooler setup.
File:Roots Supercharger efficiency map.jpg - Wikipedia, the free encyclopedia
