05wannaBproject
I just joined today and thought I'd share a success story with everyone. A few months back I replaced the VCT solenoids and got a significant improvement in performance but the engine "noise" was the same. As time progressed, I became convinced that I indeed had timing chain slap. After reviewing many threads here and videos on how to replace all the timing "set", I jumped right into the deep end:
198K miles
Replaced Timing chain, tensioners, guides, cam sprockets, crank gear and related gaskets
To test that it was all on correct and no hitting of piston to valves, I pulled the plugs and manually rotated the engine - yay, nothing hitting internally. Also made sense while torn down (and mileage) to replace plugs.
New oil pump (while I'm there) and water pump
I was expecting plastic guide pieces in the oil pan, so I had that gasket ready ... but what I found was plastic pieces in my pick up tube screen! I was driving a time bomb, am certainly blessed to have torn it down when I did.
All ford parts except a Melling oil pump - I wanted assurance of high flow and no back plate flexing.
My timing cover was ate up where 1 entire guide was "consumed" and I had metal shavings in the oil pan ... some of the engine noise was the chain playing pinball with plastic pieces of guide.
I have audio of the noise prior to repair, if interested, and a vid of some of the damage that I might could zip up.
All is well now, or better yet, it runs better than when I bought it with 44k miles. I am guess the newer engineering VCT solenoids and cam phasers/sprockets are the reason.
Next is some mods ... once my wallet recovers and the itch to turn a wrench returns.
198K miles
