is 91 octane better than 93 octane
tritonman5.4
brooklyn ny
i see alot of people with modded cars and trucks use 91 octane instead of 93.especially turbo'd SC vehicles.is 91 better for force inducted cars???
whats the difference?
panda24619
San Diego
heres a big difference price and availability. i know i run my truck on 89 octane. there is 91 availability. i havent seen 93 around San Diego. but i do know a few places that sell 100 octane for $8 a gal.
alexhozee
Netherlands Antilles, Curacao
In theory your car would drive better and use less fuel with 93.
The higher the octane the better the ignition in the cilinder.
In practice you should almost not be able to feel the difference between them.
Alex
tritonman5.4
tritonman5.4
brooklyn ny
i run my expo on 93 it runs alot better now i use to run 89 octane didnt feel to different from 87..im just not to familiar with 91 and not many gas stations carry it.i know sunoco carries it for sure.
walnuts4x4
Watertown, NY
but why would ford say to run on 87 octane? just a thought... 91 or 93 is just a waste of money in a stock motor
mmrseed
Huntsville
93 is only better than 91 if it is necessary because a custom tune dictates such. But if a vehicle needs 91 octane running 93 will contribute nothing except higher cost and neither are necessary if you run a stock motor expy which only needs 87
panda24619
San Diego
i only run chevron 89 cause i can get 11 mpg out of it. any other octane and any other company i get 10 mpg. i know not a big difference. but i have the bigger 30 gal tank. so thats an extra 30 miles i can go.
ELVATO
Orlando, FL
I run 93 cuz I'm tuned for it. 93/91 in a stock engine is a waste.
GDDYUP
NH
Here's the deal with octane. The higher the octane rating, the slower the fuel burns inside the cylinder. There was a study done many years ago on Ford Taurus' concerning octane ratings and the result of those ratings on the internal structures of the engine. The study compared the engines in Taurus' that were owned by privtae individuals and those owned by rental companies such as Hertz, Enterprise, etc. Engines were torn down and results were tabulated. What was found was that there was MORE sludge and carbon build-up in the engines owned by private individuals as compared to the engines owned by rental companies. The rental cars' engines were in much better shape internally than those owned by private individuals. Why you ask? What it came down to was the fact that the Taurus engine was designed to use 87 octane fuel. Private parties were filling up with higher octane such as 91/93 octane and rentals were being filled with 87. No one is going to pay a premium to fill a rental car with "The Good Stuff". People who owned their car were going to fill it with "The Good Stuff"..... Those who owned their car thought they were doing the right thing by filling up with a higher octane when in fact they were actually hurting their engine by doing so. The higher octane was burning slower in their engines which were designed for 87 and the result was a slower burn and more carbon/sludge build-up. In an engine designed to run on 87 octane, a higher octane does nothing more than create bad news on the internals.
Short and sweet. You really gain nothing from running anything other than 87/89 octane in your everyday Expy regardless of year. I have an 07 Limited EL. I feed it either 87 or 89 depending on what gas station I stop at. I NEVER feed it anything higher than that. Anything higher is a complete waste of money and it hurts my engine in the long run. The only reason to run a higher octane rating is if you have an engine that is desgined or modified to use that higher octane rating. The only real-world exception to that rule is if you run a programmer that is specifically set up and specc'd out to use the extra octane and even then it is going to be right on the edge unless you have modified your engine setup in such a way that the higher octane rating is neccesary to prevent detonation or to achieve a certain power goal.
Case study for octane : I use to run a 90 Mustang Notch at the drags up here in NH. The car was set up to run 87 octane. We're talking custom cams, ported intake/heads, long-tubes with single cats into 2.5" custom exhaust. Anderson PMS laptop ECU system and everything you would possibly want in a street/stirp car. I drove it to the track, ran it, then drove it home. With a 1/4 tank of 87 the car ran high 11s almost every single time if I did my part. Put 93 octane or race fule in it, 1/4 tank, and the car ran low to mid 12s every single time when I did my part...
Scientific? Hell no. But enough to prove the point of my instructors back in college. Octane means nothing more than the number prescribed in your owner's manual. Modify your car/truck far enough outside the boundries set by the manufacturer and THEN you have some thinking to do in regards to what your engine needs to be happy.
An aftermaket "intake" and some aftermarket "exhaust" is not going to give your ECU fits in it's stock configuration. Add a tuner with some custom fuel maps and such and then *maybe* your setup could take advantage of some extra octane. Maybe..... :)
Until you reach that point, spend your money on making sure your oil changes are up to date and buy a can of fuel system cleaner every oil change. THOSE are the simple things that make big differences down the road. :)
tritonman5.4
tritonman5.4
brooklyn ny
Alex
that's impression that i am under but everyone else is saying otherwise.i honestly thought that the higher the octane the better.ive notice the distance traveling up and down route 80 alot from blaisville pa to Brooklyn ny.with 93 i can make that trip on 1 tank.with 87/89 i gotta refill 1s i make it to stroudsburg pa.
NOTE I AM NOT DISCREDITING ANYTHING THAT WAS POSTED ON THIS TREAD
Travo87
Ok if your in a expy running anything but 87 just be prepared to replace your burned up valves from running it...its plain and simple...the expys internals are not made to run it for long periods of time ur just making it hotter yea the fuel burns more effeciently but your internals are paying the price your motor just insent going to last....and thats the truth unless your in a rice burner
KWT2000
NINE MILE FALLS
run what your tuned for timing and air induction is what determines what octane you need in term if your tuned for 87 you cant get as good of combustion with 91/93 thus your wasting that extra money you spent
tritonman5.4
tritonman5.4
brooklyn ny
thank you all for the insights and tough love,i think i'm gonna go kick myself in the ass now for spending so much on 93.didn't really know i wasn't doing anything to help my truck.you guys just helped save me a whole lot of money.thank you
joezek
psl, FL
Here's the deal with octane.... There was a study done ...The study compared the engines in Taurus' that were owned by privtae individuals and those owned by rental companies such as Hertz, Enterprise, etc. Engines were torn down and results were tabulated. What was found was that there was MORE sludge and carbon build-up in the engines owned by private individuals as compared to the engines owned by rental companies. ... :)
You ever driven a rental car before? I know I have, and I know quite a few others too. Number one thing we all do to a rental car is beat the snot out of it, floor it all the time, and most of all, "drive it like a rental". I personally think that's the reason there's no sludge or carbon build up. Rental companies also have a designed schedule for oil and filter changes, private parties depend on when they feel like changing oil and when they have the $$ to do it.
Besides that, higher octane "should" burn longer and more complete, and cleaner in theory. Some vehicles do get better mileage with high octane, but I'm pretty sure only carbureted engines will gain mpg with 93 octane. On several trips from FL to NY we experimented with 87 vs 94 octane (in 1984) in our 1982 buick Electra. We got 19 mpg with 87 octane and 23 mpg with 93 octane.... every time. Nowadays the quality of the fuel is more refined, the computer has better control etc. so it's probably a waste of $ to use 93.
On a side note, I found a local station selling "boat gas" which is NON ethanol 90 octane. I get 60 more miles per tank of gas using non ethanol fuel...I've proved it to myself a few times over a couple months. It's not the octane, but its the BTU's and total amount of energy per gallon that helps. Ethanol has very little energy but high octane.
