Just picked up a 1 owner 01 Eddie Bauer 5.4
Walsh82
Lake In The Hills,IL
Hello everyone. My name is Shaun from Lake In The Hills,IL. As the title states I just purchased a 01 Expedition with 188k. I'm currently in the middle of a few modifications. Cold air intake, Flowmaster cat-back, SCT tuner, and a mechanical trans temp gauge to monitor the 4R100. Looking forward to sharing intrest and advice with fellow Expedition owners.
BIG GREEN FORD
loxahatchee Florida
Where did you hook up the mechanical trans temp too? Would be grate to know. Thanks
Newport News, VA
? is your trans stock? if so is there really a need to monitor it or do you have future plans for trans as well in the future
W
Walsh82
I'm going to T into the cooler line leaving the transmission. Im in the process of removing the center console and drilling the hole to run the lead. Trans is stock and I dont have plans to tow but I'm driving to FL in a couple weeks and want to keep an eye on the temp since it will be hot out and Tenn has quite a bit of inclines.
Mediamonkey11
Enumclaw, WA
I did mine a little bit differently, and that I installed a remote transmission filter kit and tapped into the housing to install a transmission temperature probe that runs to a gauge installed in my dash.
B
bedrck46
you could also consider a blue tooth OBDII device, the torque pro app and a smart phone or tablet that way you could monitor both incoming and out going temps to see how well the trans cooler is working
