need transmission help!
cliff
Franklin, TN
I recently went mudding in my 2000 expy, and once I got back on pavement I put it back in 4AWD but it felt like I was still in 4h except for the fact that the front wheels are not engaged. Now I can only use the 1st 3 gears and my overdrive light is flashing.
Canadian Expy
Toronto ON
Sounds like you got water into some where.
I would unplug and clean any wires or sensor on the trans to start.
Someone else should chime in with other ideas
daoud el-massri
ct
what size motor 4.6 or 5.4 witch tranie w/r70 or w/r100 First I would drain all tranie fluid replace filter cost u have water in the system somware if that dose not work I have a w/70 4x4 trance for sale it has 70,000miles on it comes with torque concerted and transfer 650.00 . Hope it is just water
