no start when hot.
mike206
Olalla, Wa.
Same issue on my 01 5.4. Started first time fine, run for 10 minutes or so, key off, then no start. Solution was new fuel pump. +++++ on fp check when cranking & not starting :)
Charles Musick
Charles Musick
Va Beach
Finally got to fuel pressure test. The pressure holds at 15 psi idling, slight increase on rev. Specs are 28-45. With the key in on position not running it pumps up to 8-9 psi; specs 35-45. The spec info is from just answer . com Shawn, Auto Service Technician. I'm assuming it is correct. I'm ordering FP now. I'll retest and scan and post update.
1955moose
Thanks Charles, your posts will help others. Sounds like your fuel pump was overheating when hot, glad you got it figured out. Our members are very professional and were out to save you money, and make a mechanic out of you, good job.
Wilson
Nevada
Fuel Pressure regulator on top of the engine. Make sure the vacuum line on each end of the regulator are functioning.
