Here's the deal. My battery kept running down on my 2000 Navigator. I checked the battery and it was bad. I took it to Sam's and got a new Exide battery about 2 weeks ago. I thought that had fixed my problem but lo and behold the new battery ran down too. OK, I took a test light and unhooked the negative battery cable and touched the battery post with one end and the cable with the other end and, sure enough, I have a light indicating power is going through the system. I began to pull fuses. I pulled every fuse under the dash and nearly of them in the fuse box under the hood. I still had a light every time with the fuse out.
I had this same problem on my Ford F-250 and it turned out to be a shorted alternator. So today, I took the alternator off (not as bad as I thought it was going to be). I unhooked the wires to the alternator and I STILL HAVE A LIGHT!! I'd have bet a hundred bucks that was it. Sooooo, now I'm at a dead end. I have no idea what is pulling power all of the time now. Anyone ever had this situation or have any idea what it is? Any help is appreciated. Thanks ..
