johncomp99
Louisiana
Curious if there is any way to re-wire the power points on my 2012 el limited so that they time out with the accessory delay? Currently all power points except the Edison in rear console stay on all the time allowing the battery to drain if something gets left plugged in.
Anthony DeVor
Maryland
Not a clue but would love to change mine to acc as well. Please update if you ended up finding anything thanks. While I think about it, I guess you could pull the fuses and use fusetaps to tap off of an acc circuit and use a relay from the battery for the power to the outlets and the acc circuit to trigger the relay. If yo u want to go through all of that
Budman55
