Rear window washer.
Erich Zeppelin
Destruction Bay, Yukon Territory
Well guy's, my rear window washer stopped spraying. The front sprays just fine. So I took a small piece of wire and cleaned out the spray nozzle and still nothing. I then pulled the hose from the nozzle, tried it again and a lot of fluid shot out, so I thought, Great! I just need to clean out the nozzle a bit better. Then I tried to put the hose back.........after much cussing and carrying on, the neighbors yelling that they were going to call the cop's, I decided that I would ask you guy's. How do you put the hose back on the rear window washer nozzle?:mad: 1999 Expedition E.B.
Stoned06
Milwaukee
You probably need to warm it up since I'm sure it's fairly cold up in Alaska. Get some hot water in a glass and dip the end of the hose in the water. It should make the hose more pliable to be able to fit over the nozzle nipple.
