Hey guys, new here. I’m having an issue with RPM dropping to 300 and then coming back up to normal Intermittently. I had a cylinder 6 misfire code but had just changed plugs and boots with motorcraft about 1500k miles ago. Went ahead and swapped out the #6 plug with a new one and the code cleared but I still have the random idle issue. Might be good one day and worst the next. New mass airflow and filters all done 1500k ago. The plug I pulled had some corrosion at the tip and the ceramic was yellowed near the base. Any thoughts would be appreciated. Engine is not pushed hard and has 178k on it. Also cleaned out throttle body at the time all the other work was done.
