Rubbing sound left front wheel 2016 Expedition
68lemans462
Mile high
I have a 2016 expedition with 95k miles. The truck will make a rubbing noise at low speeds, especially when decelerating. At first I thought it was the hub assembly so I replaced it with a MOOG part. Same problem so I replaced hub assembly again under warranty. Seemed to get better but still happening. I then went completely through the IWE system. Everything appears in order system holds vacuum, solenoid works, etc.
I'm wondering if this actuator could be bad even though it holds vacuum. Where do I go next?
Nico79
Abingdon VA
I have the same issue!
2017 with 135k miles. Replaced wheel bearing, no change in noise. Runs & Drives great. Have check EVERYTHING and have no idea where to go next.
Any luck with yours?
Fasttimes
Miami
I'm getting a rubbing sound on my left front when I turn right. Took to shop and they couldn't find anything. Just did a 2000 mile road trip and now it's worse. Going to take it back to the shop or to a different shop.
