Subwoofer install
MJohnson3118
windsor, colorado
Hey hey hey. I have a 24 expedition xlt with the 6 speakers. Wanting to put a subwoofer in and needing help. Anyone have any suggestions or walk through a for me?
BlackBetty
Army
Surprise, AZ
Had a ‘16 Ellison that came with a Sony system. OEM sub installation was in the furthest rear driver side corner. It was not very good; in performance that is.
Ended up removing the speaker enclosure and ditching that horrible speaker. Replaced with a Kicker 8in. Had to make minor modifications to the enclosure, as the speaker mounting did not line up.
Filled the enclosure with poly-fill to trick the speaker into thinking it was in a larger volume enclosure.
Additionally, because the speaker out-spec’d the OEM model so much I also added an amp. Mounted it under the driver side third row seat. FYI: spaced the seat bolster brackets to gain clearance for an unobstructed power fold.
Could I have mounted a larger speaker and amp yes; kinda wanted to. But, wanted something that didn’t take up space, obstruct the way the truck was used, and be totally out of sight.
If you can find that JL enclosure in the advertisement it will allow you to mount a 10in sub in the stock location. Mind you, you’d need to find your model year equivalent.
Once I came across that it was a no-brainer. But, I could NEVER find one. Anywhere!!! Good luck on whatever you decide to do.
P.S.- the other thing I added (might be getting the name wrong) was a digital converter. Gotta take the DSP signals the vehicle produces and turn them into usable signals for the amplifier. Don’t remember the brand, but I mounted it in underneath middle row cup holder. If any adjustments needed to be made all I had to do was pop the cup holder out. Don’t have a pic of that mounted; or, I can’t find it. Sorry.
MidnightBruce
California
If you're adventurous like me, I did an infinite baffle 15" under the cargo tray. Kicker KEYLOC, 15" SI SQL15, Audiozerone (Amazon cheapo), some windynation 4awg and a bit of fabrication. I was not afraid to cut some non structural sheet metal . Been over a year bumpin in Hot AZ and through monsoons as well as lots of car washes . The magnet of the woofer sits about 1/2" off the spare tire carrier under the back. Keeps the wife happy that she maintains all her cargo space.1000007921.png1000007922.png1000007923.png1000007924.png1000007925.png
GenSuper
Orem, Utah
I installed a JL Audio Stealth box. Expensive but well worth the money. Bolts right in to the same place as the factory subwoofer with no mods. Added an amp of course but sounds exceptional and I have an audio ear.
