Could you elaborate a little more on the sensitivity of the "electronically controlled components" to fluid contamination? I'm not understanding that.To each their own. Here are my observations from changing fluids in my (new to me) 2014 with 132k miles :
Coolant : Original "gold" coolant looked destroyed. It was turning brown and had gummy/sticky floaties in it. Flushed / replaced with Prestone green OAT coolant.
Power steering : Fluid was dark brown and looked nasty. Replacement fluid (Mercon LV) is bright red.
Brake fluid : Fluid in reservoir looked clean and had a slightly orange tint. If I knew it was in such good condition, I wouldn't have changed it (synthetic DOT 4 type).
Front diff : Fluid was dark gray color and smelled pretty bad. It looked like it was full of microscopic gray particles. It wasn't burnt though, just very dirty with metallic sludge. Fluid changed for 75W90 synthetic and a magnetic fill plug was installed to reduce future contamination (not factory equipped).
Transmission : Fluid / filter did not appear to have ever been changed. Fluid was dark red in color, but in good condition overall. Fluid filter casing was covered in microscopic metal particles and so was the pan magnet (no large chunks, though). It definitely could've used an earlier fluid/filter change to keep all solenoids happy...
Transfer case : Fluid had been changed in it before, as evidenced by the slightly damaged fill plug. Fluid was nice and bright red. I changed it anyway, just to be safe. Magnetic drain and fill plugs will be installed on next fluid change (not factory equipped).
Rear diff : Hard to tell if fluid was changed, as it was in pretty good condition and slightly greenish in color. The rear diff drain and fill plugs are equipped with magnets though, so that might've kept the fluid cleaner than the front diff. Changed it for new 75W140 synthetic.
So, saying that fluid changes "don't do anything but lighten your wallet" is a bit of an ignorant statement, as these electronically-controlled components are very sensitive to contamination... and clearly, most of these fluids were definitely due for a while.
Never ask a barber if you need a haircut.Shops ALWAYS tell you to change it more often, that's how they make their money... Don't waste your money!
How about surgery?Never ask a barber if you need a haircut.
Thanks for the replies!! I watched the video. I’m going to go ahead and wait another few months probably. They just do a drain and fill now typically? I remember hearing about the flushes causing problems on high mile vehicle when the oil hasn’t been changed. Think I’m just paranoid bc I love my car and want it to last a long time and don’t want to screw things up![]()
Do you honestly think that any shop or dealer has more.knowledge than the manufacturer themselves?
First: brake fluid should still be checked from time to time for signs a seal is breaking down. If you dont catch it in time you may have to overhaul the whole system including the abs (ask me how I know).
2nd: the color and smell of the fluid will tell you a lot. Dont just rely on numbers. 3k mile oil change in 1 vehicle could be a waste of money but in another could have saved the engines life from a disaster! My 95 GMC gets changed with good old dino juice every 6 months even with only 500 miles ticked off during that time. Be cautious until you learn your truck.
