TSB 24-2188 - 2003-2020 Expedition/Navigator + F-150 - 4WD - Grinding/Clicking/Ratcheting Noise From Front Wheel Area July 23, 2024
HazBeen
Great Lakes
TSB 24-2188 4WD Grinding/Clicking/Ratcheting Noise From Front Wheel Area - July 23, 2024
This bulletin supersedes 22-2219. Reason for update: revised Part List and Service Procedure to clarify applicable steps by vehicle application
Model:
Ford
4WD
2006-2020 F-150Non-Raptor
4WD
Lincoln
2003-2020 Navigator
4WD
Markets: North American markets only
Issue: Some 2003-2020 Expedition/Navigator and 2006-2020 F-150 (non-Raptor) vehicles equipped with 4WD may exhibit grinding/clicking/ratcheting noise from the front wheel area. This may be due to partial engagement of the IWE. To correct this condition, follow the Service Procedure to remove and cap the vacuum supply line or to reprogram the TCCM and replace any worn vacuum and/or IWE components.
Action: Follow the Service Procedure steps to correct the condition on vehicles that meet the following criteria:
• One of the following vehicles:
- 2006-2018 F-150 (non-Raptor)
- 2019-2020 F-150 (non-Raptor) equipped with a torque-on-demand transfer case (with 4A position on the MSS as shown in Figure 2)
• Equipped with 4WD
• Grinding/clicking/ratcheting noise from the front axle area
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Service Part New Vehicle (SPNV)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SPNV/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2003-2020 Expedition/Navigator, 2006-2020 F-150 (non-Raptor): Diagnose And Repair Vehicle Following The TSB Service Procedure
MT242188​
Actual Time​
Repair/Claim Coding
Causal Part:3C247
Condition Code:D4
For full information, including the Parts List and Service Procedure, see TSB 24-2188 attached below as a PDF document...
  • TSB 24-2188 - 4WD - Grinding-Clicking-Ratcheting Noise From Front Wheel Area - July 23, 2024.pdf
99WhiteC5Coupe
TSB 22-2219 4WD Grinding/Clicking/Ratcheting Noise From Front Wheel Area - July 23, 2024
Model:
Ford
4WD
4WD
Lincoln
2003-2020 Navigator
4WD
Labor Times
MT242188​
Actual Time​
Repair/Claim Coding
Causal Part:3C247
Condition Code:D4
If the TSB is followed for the torque-on-demand feature (2015 Expedition Limited 4x4) - it eliminates the 2WD feature and only enables 4A, 4H and 4L?
H
HazBeen
Great Lakes
You are correct that TSB 24-2188's torque-on-demand Service Procedure, removing and capping the Integrated Wheel End (IWE) system's vacuum source, fully deactivates 2-wheel drive capability.
Per the 2015 Expedition Workshop Manual, which essentially describes all the TSB-affected model years...
When the 4WD system is in 2WD mode, the 4X4 control module supplies a ground path to the IWE solenoid to apply vacuum to the IWEs (disengaging the front hubs from the front halfshafts). In 4WD mode, the 4X4 control module does not supply the ground path to the IWE solenoid, vacuum is not applied to the IWEs and an internal spring keeps the front hubs engaged to the front halfshafts.
The quoted-from Workshop Manual section and a supplemental illustration are attached below as PDF documents.
Good luck!
  • Four Wheel Drive (4WD) Systems - Description and Operation - 2015 Expedition Workshop Manual.pdf
  • Integrated Wheel End (IWE) System Component Locations - 2020 Expedition Workshop Manual.pdf
99WhiteC5Coupe
Good luck!
You probably can’t answer - but why would Ford provide a TSB that eliminates a vehicle feature that the owner purchased? Why wouldn’t the TSB have instructions on how to repair the feature?
What does a Ford dealer do when a vehicle owner with the torque-on-demand feature brings their vehicle for repair - but does not want the 2WD feature eliminated?
spape100
waco Texas
I am having this issue with my F-150 and I found this post that shares how to actually repair it so that the 2WD feature isn't eliminated.
In short, you can order the part number FL3Z-3A788-B for about $20 and replace the white check valve with an updated blue check valve.
dtv_engineer
CA
FWIW: I have a '19 MAX FX-4 w/ HD tow and it either came with the blue valve or the valve was installed later. I believe it came with the valve since I haven't had the truck at the dealer in 2-3 years.
2003FTW
Oregon
Our 2003 Expedition has this problem but the vacuum lines don't match the service bulletin diagrams very clearly. I don't want to pull the wrong one.
Is driving it in the A4WD mode (and just not using 2H) a sufficient long term solution? Is there any added benefit to pulling the line and capping it as described in the service bulletin?
Thanks so much for posting this, btw.
Expensedition
Newport, RI
I found that the 4WD actuators at each front wheel fail over time. They are not that big of a deal to replace but you do have to pull the CV axles. They are vacuum operated and they can seize up over time. I replaced mine along with other parts during a front end rebuild.
