BlakeMAX2019
Our 2019 MAX AC is acting funny, and I’m curious if anyone has run into something similar.
About an hour into a road trip, with the AC on and the fan set to high, the fan will suddenly drop to what feels like the low setting—even though it’s still set on high. At the same time, the air coming out isn’t as cold as it normally should be. Basically, the airflow is very weak even though the fan control is on high.
Here’s the odd part:
- If I turn the AC button off but leave the fan set to high, the fan immediately ramps back up and blows strong again.
- I kept it like this for about 10 minutes (fan on high, AC off), then pressed the AC button back on—and the air got cold again with the fan blowing hard as it should.
- This has happened a couple of times before, but this was the first time I experimented with turning the AC button off to test it.
