thewishkah
Ok so heres a little background.. I bought my 97 4.6 back in April of this year with 112k miles or so. When I bought it there were some things that needed attention, It ran a with a slight hesitation or a miss but not too bad at all. First thing I did was change the air filter which was horrible, probably the worst I had ever seen. At the same time I cleaned the MAF, and the Throttle body plate. This made it run a little better but I could still hear that it wasn't perfect. Next thing I did was run some seafoam through the brake booster and the gas. I got a decent smoke show but didnt run any different. Next up I changed the fuel filter and that did nothing either.
Fast forward a few months I start getting an idle drop while going to park, usually it recovers but I've had it stall twice. So I did the plugs (2 of which were loose in the back pass side) and the gap ranged from .058-.072 Got them all finished up thinking this had to of been the culprit. Ran with more power for sure but still having the idle drop when going into park. Next step was removing the TB and cleaning out the EGR ports. They were really bad, one was completely blocked and the other was about 1/3 clogged. I cleaned it out really well put in all new gaskets, a new hose for the evap valve since the out side of it was coming off as black dust, a new pcv valve even though mine tested fine I figured I might as well while im in there and I cleaned the IAC again as it had been sticking in the past after being on the highway(corrected that issue a few months ago but cleaned it again anyway).
I checked all of the other vac lines and they seemed to be in good shape. I checked my transmission fluid and it is pretty good in color and at the right level as I have read if the level is off it could cause issues while going into reverse. Im running out of ideas here, the truck hasn't thrown a code yet even after it stalled. My next thoughts in this order would be IAC replacement, o2 sensors, or torque converter. Any insight on this issue would be a great help. And yes after each repair I disconnected the battery so it could re-learn with the new fixes. Thanks in advance for any help you may be able to give.
P.S. the idle drops down to around 400 after I change gears and hit the gas and then remove my foot from the pedal (imagine parallel parking)
