#@$%#@$#@$#@$#@$#@$ Front Cover
BrandonB
Kansas
So I took advantage of a nice warm sunny day this evening to go out and finish putting my truck back together. Everything coming together nicely.. SNAP.
The guide wheel on the front cover, was tightening it down not even to the tightness to torque yet and it snapped off the aluminum offshoot it was connected to......
Now it looks like I get to buy a new front cover and take everything BACK off.
B
bedrck46
Guest
Are you sure it was a Sunny day or do you have a dark cloud over your head I bet you just love doing things twice
B
BrandonB
Kansas
Well i'm glad it broke now vs later when I was driving and had even more stuff put back on.. ..
Now I get to find a timing cover somewhere.. Checking dealer and junk yard tomorrow I guess.
toms89
technical advisor
MD
Maybe you are much stronger than you think !?
:worthy:
B
BrandonB
Kansas
Entirelly possible, but it wasn't even to the point of feeling tight. :/ I saw someone on the mustang forum had the same problem under almost the same circumstances and was able to "fix" it by just getting a longer bolt and making use of extra threads. I suppose I could do that - there is still about a 1/4" of threads in the front cover. I could get a slightly longer bolt and some jb weld and "fix" it if I have to. But at this point I just have to take the valve covers, ps pump and crank pulley back off to get the cover off so I might as well replace it - if I can find one.. Alternatively I could have my dad weld it but I don't know how well that would hold either.
toms89
technical advisor
MD
Agreed.
Sorry about your misfortune! Really sucks when things like that happens. Kind of screws your day.
IMINYOURCHAIR
Altoona Alabama
It could've been worse.. I broke a bolt off in a water pump gasket fix on my buick lesabre. the engine was to be removed to get proper access to drill the bolt out. I just bodged it together as it was probably the 50,00th thing coolant related to break with that car. tragedy though
B
BrandonB
Kansas
I'm really just tired of spending money on the thing to be honest. I knew it was a gamble when I bought it. It just sucks when your almost done and have to take so many steps back. It doesn't sound like i'm alone either - looking around at other forums it seems like that is a commonly broken part. Wish someone would make some sort of aftermarket idler that shares the same 3 bolts as the tensioner or something.
toms89
technical advisor
MD
Metal fatigue or bad castings ??
Might be worth tapping it out the rest of the way and using longer bolt if they are not broken?? But then that might break it if its ready to go. Catch 22...
