I think this info would like to live here too
There are a few ways to ID an LSD:
1. On the door jam, find the data sticker, get the axle code, and look it up.
2. On the differential housing, there should be a metal tag. It will have two rows of characters on it. At the beginning of the bottom row, it will start with something like 3L55 or 3 55 for example. 3L55 means it is a 3.55 limited slip rear, while 3 55 means it is a 3.55 open rear (the L stands for limited slip).
3. With both front wheels carefully chocked on level ground, trans in neutral, emergency brake off, jack up one rear wheel. If the wheel will spin freely with the other rear wheel on the ground, it is an open rear. If it will not spin freely, it is limited slip.
4. Don't worry about whether it is limited slip or not, just drive it and enjoy.
(but make sure the juice has the required additive package if it's an LSD
