I don't know but I don't think so because all you are doing is turning on or off features they already programmed into the various modules. I did see that you can turn off the horn honk thing that you didn't like.This is something I should investigate. Big question is does this void your warranty in any way?? This "tampering" may be used by Ford to deny warranty service if something should happen. Are we safe here??
I pulled this link to a FORScan tutorial from the F150 forum that may be useful
https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
Here is a link to his (the person that wrote the above doc) spreadsheet showing all of the areas that you can adjust.
https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466
Which honk do you want to remove?I specifically asked the dealership and service if this could be done (assuming it was a programming change) and the answer was no. They scheduled me in for an all day appointment to have that done under warranty by tearing into the dash. Seeing many headaches coming from that I cancelled the work and decided to suck it up and live with it.
BUT, if this ForScan can make that change, why would Ford not know about it? Their engineers wrote the code... If it is true that I can make this change with ForScan, I will investigate. Maybe even ask Ford Service about it.
When I need to get out of the vehicle (in park while running) with the key fob in my pocket, I close the door and the vehicle beeps twice as a reminder that it is still running and no key is present. Drives me nuts. My wife's 2015 Venza does not do this and no other vehicle I have owned has done this. No option to disable.
Dealership does not know how to disable the double honk.
