Upgraded Differential on 2nd Gen?
Vancouver Bob
Vancouver, WA
Hey Guys....and gals. My '03 Expy has open differentials and I'm very interested in upgrading to either a Eaton Truetrac limited slip or a locker. I've done a bit of research and I'm discovering that not many or anyone offers something for the 9.75 IRS rear end. Evidently the rear drive axles are the type that have a circular spring clip that sits at the end of the shaft which then locks the shaft into place when the clip reaches a slot inside the side gear. Unlike the shafts that have a ring clip that gets inserted at the end of the shaft once the shaft is installed into the differential. ARB supposedly issued a news release saying they offered a locker for the 9.75" 34 spline but come to find out that it's not compatible with the IRS. I talked to an ARB tech rep and he said the side gears would need to get machined for it to work.
For the front, I think it's an 8.8" same as the F150 but not positive. If it is, there'd be more offerings.
Anyone do any upgrades?
Thanks!
Bob
Hamfisted
Ft Lauderdale
Probably quickest and "easiest" way to do it is just go to a salvage yard and find an Expy or Navigator with a "H6" code on the door jamb sticker ( 3.73 Limited Slip ), and pull and swap with that complete axle. Unless you're going rock crawling that should be good enough. The limited slip axles were actually more common than non-limited slip .
-Mike
Vancouver Bob
Vancouver Bob
Vancouver, WA
Hi Mike... that would be the easiest approach. What I hear though is that a clutch type limited slip becomes an open diff after 20K miles or so as the clutch packs wear. They are replaceable though. So an option would be to simply rebuild during the install and be good to go for a few years which may very well be good enough. Thanks for the suggestion!!
ExplorerTom
I wouldn't do the clutch limited slip. If it is worn out and you get into a situation where you actually need it- you'll want a diff that works.
Vancouver Bob
Vancouver Bob
Vancouver, WA
That's what I was thinking too. Probably worth the extra money to put towards a swap to something better than a standard LSD. I'm also planning on changing gears while I'm at it (well... I mean while the shop is at it). Figure everything is all torn apart so cost to have them swap out the differential would be essentially free. I'm just not finding anything for the 2003 (and on) because of the axle setup with the independent rear suspension.
plumcolr
freehold nj
Dunno about the 20k wearout. Mine has 180k on it and the torque wrench test still shows around 100 ft-lb. I believe spec calls for 50-200 ft-lb.
Vancouver Bob
Vancouver Bob
Vancouver, WA
Good to know, thanks!
I can't remember where I read that.... but I'm sure all LSD's aren't created equal. I'm thinking putting in a new LSD differential may be the ticket since I can't find anything else that will work without doing some modification.
plumcolr
freehold nj
I suspect that people that use them hard will get significantly less wear than normal drivers.
I'm pretty easy on cars, except cosmetically ;-) last 2 both went over 300k from new.
Vancouver Bob
Vancouver Bob
Vancouver, WA
Yes that's absolutely true too.
Was reading a few things last night that said Expys with AdvanceTrac all have open diffs. Anyone know if that's true? I thought AdvanceTrac came standard. I wouldn't want to muck with the system by adding something it isn't expecting and cause problems.
Funny about the cosmetics comment! :)
