jeff kushner
Motorcycle chain lube!! I realized this last year right after buying my truck and it's PERFECT for them! Chain lube's come as sprays that are very viscous when first applied and it easily flows into the pin shafts, joints etc. Then, after a few minutes the carrier fluid evaporates and leave the lube behind....it really is the perfect lube for these assemblies! BE SURE TO USE PRIOR TO WASHING YOUR TRUCK!
You def don't want to apply this AFTER getting all the parts wet so do it before you wash your truck!
I've been meaning to post this and kept forgetting!!
Here's an example but there are a hundred different brands...any of them will work....just stay away from "chain wax"...it's a similar but different material. It will work but wax does not lubricate like grease! Most are using WD40 which is a very non-resilient lube but it does work....the chain lube is worlds better though!
jeff
jeff
