Retros work and cost less than $400 if you do the work yourself. Get a threaded shaft projector and it's easy stuff!
Lots of options on eBay. Most people are going to say these are junk and they probably are compared to a retrofit with high end components but in your situation this should get you better light than you currently have. I did a search on eBay for 2009 Ford Expedition projector headlights and this is what I turned up:Thanks- I think I just have reflectors. I tried the morimoto 9008/H13 kit & ballast and all that BS- won't waste that money again- already did the retrofit source for that attempt. I don't know what I'm doing and don't have the time, so I definitely just want to go plug&play with the whole headlight- not individual pieces. With that being said, what site sells the complete package where I don't have to go into replacing the bulbs, but I can just unscrew the entire assembly and swap in a new assembly?
Bwahaha, preach brother!This is what I feel like around here
This is actually the owner of bullseye retrofits
You guys that say a projector retrofit is the ONLY way to go crack me up (somebody has to say it). A properly aimed reflector w/HID's is just fine.
Let the flaming begin!
