Had this problem for years. When it gets cold below freezing the drivers door occasionally doesn't latch, just bounces when you close it. Lights stay on inside. Start to drive and door swings open so you have to hold it. Got tired of holding it so I actually used to put a strap across my body to other door handle (never said I was sharpest tool in shed). One day I figured out that if you activate door lock/unlock with key fob ... it latches. What is the problem here and how can I just make it go away? I've tried spraying wd-40 on latch mechanism and lubricating door lock with graphite spray. 03 Expy XLT
