gixer2000
Retrofit or Bust
Where'd you get them? Do they just slide in or do they attach with tape?
EBay
They go in the channel and attach with tape inside the channel
EBay
Sure isAre these the same ones?
https://www.rockauto.com/en/moreinfo.php?pk=5725200&cc=3305849&jsn=436&jsn=436&jsn=436
Sure is
Ive never had an issue with the windows going up and ive had these for 3 years.I have the AVS and they didn't fit well in the back causing the windo to stop before it got to the top. Well a few weeks ago the driver's side cracked but on the upside I don't have to push it out now to get the window up.
I guess I should get it replaced soon.Ive never had an issue with the windows going up and ive had these for 3 years.
Thanks, I swapped them side to side and used to be a dealer for them. It seemed fairly straightforward.Check your install. The instructions are not very clear, but they will fit properly and the window will go up just fine if installed correctly. Again, the instructions are not crystal clear, just read them a few times and it should make sense.
Also, for anyone that owns the AVS/Lund, they have a lifetime warranty. If they crack they will replace them. Just contact customer service.
Never had a problem with them.
