Second row passenger roof air vent
benyl
Calgary
Does your work? A/C full tilt and no air is coming out of it. Drivers side has full flow.
This is what I get for buying a first model year of a new generation...
Uturn
Did you check the setup? The rear vents can be controlled by the front or at the rear if the rear controls are enabled. Depending on the front setting sometimes they just will not blow hard using the front controls. If you want more air in the back, enable the rear controls and let whoever is back there crank them up or reach back and dial them up yourself, you may be surprised.
B
benyl
Calgary
The other 3 rear roof vents blow full. It’s just the second row passenger.
Kelvin Pratt
texas
I don't know if this will help but on my 17 Nissan Titan I had a similar problem. It was one of the flow gates got stuck. So I drove a little bit and turned the heat all the way up and let it run for about 2 or 3 minutes then set it back to ac full blast and the gate lifted. Had no problems after, worth a shot....
B
benyl
Calgary
Update: duct was completely missing from the factory.
the_plugger
