07navi
I guess an avid camper might even buy it when the time comes.
Your truck so do what you like. I'd be a little spooked junking airbags... you know, the "just my luck" sort of thing. But paint it and put them back would be kind of cool. Does the spray on stuff come in colors? Be curious to see how it turns out.
Odd that here in New York, the second most fascist state of the Union, air bags are not required for the annual State inspection, and the car would pass with the airbag light on.
You should consider that the airbags already create significant insulation where they are rolled up. Ignore that area entirely. Mask it up entirely before spraying. If any of that spray insulation gets on the airbags, they will stick and won't unfurl. The trim pieces and headliner that normally cover them are for protection of the system and break away when the airbags unfurl. Don't gum those up or the airbags won't work.
You realize, don't you, that you are messing with explosives, right? If the airbags are restricted with your lizardskin and polyiso (whatever that crap is) you're mucking with your life and whoever's in the XP with you. Definitely not a good idea. Just because you can remove them, doesn't mean that it's a good idea or that they will work PROPERLY and SAFELY when you try to put them back in. Yeah, I agree with ManUp, you're just going to hurt yourself one way or the other. And yep, I'll take that bet.
How are you going to insulate the windows? they are definitely a source of heat gain/loss.Yes, I'm turning it into a camper. No you didn't miss a post. I never mentioned why I was doing it.
