How are you going to insulate the windows? they are definitely a source of heat gain/loss.
Yea, all the windows are definitely problematic.
I will make custom tight-fitting covers that have insulation in them.
I've camped in my Expy for up to 9 days in a row where it gets below freezing at night. I have "clothes, hat, gloves" I wear in my sleeping bag and a blanket over the bag if I need that. Toasty warm. Until I have to get up and go outside for relief. Here is a nice addition I use on the side of the Expy for when its raining or protection from sun. I've never figured any safe way to heat the inside of the Expy so I would have no use for insulation. I used to have a cargo van that I spray foamed the floor, walls, ceiling ... and it was NICE to have that. We would get a few people in there (70's) and body heat was enough to keep it warm inside. Of course you may be trying to keep heat out not in?
test
You use (or plan to use) a diesel or propane heater inside a closed Expedition.Everything I'm doing is to keep the heat out and cold in when running an AC. I have a 5K BTU AC that uses up to 410 watts when the compressor is running. The more efficient the insulation is will cause the AC compressor to run less and use less power. Which is my main objective.
For heat, I have a 2K diesel heater and Olympian Wave 3 propane heater as a backup.
I would figure that would be a death trap, but what do I know?
Oxygen good .... Carbon Monoxide bad, unless you want to take a long nap.
