Identify button on dash?
2020-MAX-Limited
Colorado USA
Can't find this button (circled in yellow) in the manual. It is a simple push button just above the instrument panel brightness adjustment.
Yep, ejector seat it will send you right through the roof.
turtle019
MI
Aftermarket. I take it you got your truck used? Anything obvious the previous owner added like lights?
Yupster Dog
Super Moderator
Super Moderator
Not another mystery button. I'm still waiting to see what the buttons did on the first two threads about a mystery buttons to get solved.
They seem to show up out west, first one was in Utah and the other in Arizona.
Must be remnates from Roswell.
Hamfisted
Ft Lauderdale
Drive it around the block at night and hit the button and see if any lights come on or off. Or speedometer dies or interior lights go out even with the door open.
dcsang
Is that a maintained button or momentary button?
If there's nothing audible or visual (at night as suggested) that can be detected then prepare to trace wires if you're curious enough. Since 'ejector seat' and 'plaid mode' were taken I'll suggest aftermarket lighting (light bar?) that may have been removed.
I have a 2015 Ford Expedition Limited 4x4, purchased new.
There is no button above the panel brightness adjustment rocker switch.
I was more worried that someone would post again, asking what is the best oil filter to use.........
