Transmission Jerking Hard
Explor2Exped
Nashville, TN
This only happens when the truck is going under 1,500rpms uphill. If I press the gas up to 3,000rpms it doesn't jerk at all.
Why is it jerking at low rpms?
Anybody have this problem before?
Any help & feedback would be greatly appreciated.
jacks3am
michigan
Any CEL's? mine stumbles at around 1200 rpm's because of a vacuum leak, look into that
Explor2Exped
Explor2Exped
Nashville, TN
Could be a vacuum leak because my air conditioner does that blow to the defrost problem.
No CEL, thank God..
Yeah I think it does it exactly at 1200 rpms.
97_edition
I think mine just did this over the weekend. It didn't jerk hard though. At first I thought it was a miss but I tramped the gas and it took off and no jerk or hesitation. But I noticed going uphill slightly if I just keep it under 1500 rpm it will give a little jerk. Only does it once in a while though. I too have no CEL.
jtbmjb
Byron Center MI
What is CEL?
My Truck is doing this and getting worse...
What is CEL?
I have told told it might be the torque converter as well...
WCAWI
WI
Most probable cause is a bad ignition coil. Its hard to pin down unless you have a scanner hooked up to it though.
mlself
